A peer group has had the soft reset with stored routing information behavior enabled or disabled whilst a session is already underway to a peer in this peer group. The change will not take effect for the peer until the session is restarted.
This is an internal condition needing technical assistance. Contact technical support with the output of "show tech".
Warning
Soft reset with stored routing information has been enabled or disabled for a peer group whilst a session is underway for a peer within this peer group. The setting change will take effect for the peer when the session is next restarted. VR: %p1% Peer index: %p2% Peer group index: %p3% Peer group soft reset setting enabled: %p4%
| Name | Type |
| p1 | uInt32 |
| p2 | xInt32 |
| p3 | xInt32 |
| p4 | sInt |
